Results 1 to 5 of 5
Thread: help in installing 'Visual web developer 2010 express' using Web platform installer
  1. #1
    kunu's Avatar
    kunu is offline Windows Enthusiast
    Join Date
    Oct 2010
    Posts
    97
    Default help in installing 'Visual web developer 2010 express' using Web platform installer
    hey
    I was installing Visual web developer 2010 express edition using "web platform installer".
    during this process first it downloaded the software and then it started installing this in
    my system.
    but the problem arrived as this installation process continued and "it did not finished at all" till i forcefully shutdown the PC and there was nothing installed in PC.
    I have tried 2-3 times but nothing happened at all.
    Please help in installing and over coming this problem......
  2. #2
    LeeW is offline Gold Member
    Join Date
    Jan 2010
    Posts
    741
    Default
    What operating system are you running? Also, you say you are forcefully shutting down the pc, what exactly is the installation doing? Is it just running through the install and doing nothing afterwards? Or are you getting any error messages after starting the installation?
  3. #3
    kunu's Avatar
    Join Date
    Oct 2010
    Posts
    97
    Default
    i am running windows 7 (32bit). its just running through install and doing nothing afterwards?
  4. #4
    rkonit's Avatar
    rkonit is offline Gold Member
    Join Date
    Jul 2008
    Location
    Pilani, India
    Posts
    1,363
    Default
    For your concern, could you please try the following steps
    - Check? you logged-in administrator account
    - Have you ever tried offline installer to install VWD2010? If no, please try to use some download manager software to download it from:
    Direct Download Links of Microsoft Visual Studio 2010 TRIAL EDITIONS and Express Edition
    - After you have downloaded this ISO installer, you can extract it with some third-party tools like WinZip.
    VWD2010 offline installer will be included in the extracted folder. You can directly run ...\VWDExpress\setup.exe file to install VWD2010.
    - Temporarily disable the Anti-Virus software
    Hope this helps! If you have any concern, please feel free to let me know.
  5. #5
    Withatur is offline New Member
    Join Date
    Jun 2015
    Posts
    1
    Default
    I think it will be good if you try to use an operating system that is supported in your program. Microsoft Visual Basic Express 2010 for 32 and 64 bit which is compatible in your computer.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
