Results 1 to 2 of 2
Thread: AV cable from Garmin Nuvi200 to 7" Monitor
  1. #1
    nichos is offline Windows Enthusiast
    Join Date
    Feb 2010
    Posts
    108
    Default AV cable from Garmin Nuvi200 to 7" Monitor
    Hi,
    Can I get/make an AV cable to join a Nuvi200 with a 7" Monitor?
    I install in my car the Rear View Camera & Monitor below, which say can be interfaced as well with DVD/DVR & GPS.
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=120956549024
    The vendor send me to Garmin & in turn they send me to to Maplin or RS components but no luck.
    Am writing in the off chance that a magician somewhere might help me. ...thanx ......nick
  2. #2
    DustinH's Avatar
    DustinH is offline Senior Member
    Join Date
    Aug 2008
    Location
    Boardman, OR
    Posts
    243
    Default
    Does it only have the USB connector? I don't think you could do it unless you opened it up and created a custom cable from the built in display to a monitor cable.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
