1. #1
    Needhelp is offline New Member
    Join Date
    May 2013
    Default Need help - Problem with Icons on Lower Toolbar Shifting to the left
    I have Windows 7 on my computer and Internet Explorer version 10.0.9200.16521. On a daily basis, when I wake up in the morning, the ICONs on my lower tool bar that used to be on the lower right side (smaller ICONs for HP, Norton, Volume, etc.), have shifted over to the left. When I run my cursor over the ICONs, they are not showing the correct program associated with the ICON. I re-start my computer and that seems to solve the problem, but then it reappears the next morning. Does anyone have a fix for this??
  2. #2
    HappyAndyK's Avatar
    HappyAndyK is offline Site Administrator
    Join Date
    Jun 2008
    You are saying that the icons from the notification area or the system tray are shifting to the left!? :| I have never heard this happening...
    Maybe you could right-click the taskbar and check Lock the taskbar...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Log in
Log in
