Like Tree1Likes
  • 1 Post By HappyAndyK
Thread: Help: IE 10 Won't keep default browser settings. Need help.
  1. #1
    Curmudgeon is offline New Member
    Join Date
    Jun 2010
    Location
    Greensboro, NC
    Posts
    2
    Default Help: IE 10 Won't keep default browser settings. Need help.
    Hi.
    Running Windows 7 x64 Professional. After installing The Microsoft Virtual Machine, Internet Explorer keeps displaying notice that it is not default browser, do I want to make it the default browser. I click Yes, It keeps repeating the notice each time I open the browser or a new tab. Have already gone into Tool/Internet Optioons & set IE as Default, but it won't stick. Anybody have a fix for this?
  2. #2
    Digerati's Avatar
    Digerati is offline Windows Enthusiast
    Join Date
    Apr 2010
    Location
    Nebraska, USA
    Posts
    95
    Default
    Most problems with IE are due to misbehaving add-ons so you might want to check there, or try running without add-ons and see what happens. Also, you can disable (uncheck) the setting where IE always checks to ensure it is the default under Internet Options > Programs.
    If you have any alternative browsers installed, you might want to ensure they are not set to make them the default.
  3. #3
    HappyAndyK's Avatar
    HappyAndyK is offline Site Administrator
    Join Date
    Jun 2008
    Posts
    7,459
    Default
    Have you installed any other browser? Maybe some other program keeps changing the status. Could you verify that first please?
    Paul85 likes this.
  4. #4
    GayleTek is offline New Member
    Join Date
    Sep 2013
    Posts
    2
    Default
    Try YAC virus removal tool from virus-delete.com, it will helps to fix your browser setting, default homepage, default search engine. Such annoying notices will never show up again.
  5. #5
    Matrix's Avatar
    Matrix is offline Senior Member
    Join Date
    Jul 2009
    Posts
    400
    Default
    Quote Originally Posted by GayleTek View Post
    virus-delete.com | WOT Reputation Scorecard | WOT (Web of Trust) !!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Log in
Log in
