my laptop is lenovo y400, and i run the application called battery gauge reset from energy management program.
after run battery gauge reset
my first problem. I always choose maximum battery life. I plug-in the adapter but my battery still discharging then my battery running low until my laptop off. (*in battery icon, i didnt get text like plug-in)
my second problem. If i want to charge my laptop, first i must run my laptop without battery, then while my laptop running i replace the battery.
is this problem connected to Microsoft acpi-compliant control method battery
anyone can solve my problem?
thanks before
sorry if my grammar is bad
