DOWNLOAD: Best tool to repair Windows problems & optimize system performance | Best driver update software for your PC
Results 1 to 2 of 2
Thread: Better operating system than 64 bit?
  1. #1
    bkdroid13 is offline New Member
    Join Date
    May 2019
    Posts
    8
    Post Better operating system than 64 bit?
    I want to ask one general question here, We have seen 32 bit and 64 bit Operating System.
    Is there any other larger size bit Operating System exist? If yes can you please share the link to download it.? i want the best speed operating system.
  2. #2
    Lewis-H is offline Windows Enthusiast
    Join Date
    Mar 2020
    Posts
    118
    Default
    Simply put, a 64-bit processor is more capable than a 32-bit processor, because it can handle more data at once. ... Here's the key difference: 32-bit processors are perfectly capable of handling a limited amount of RAM (in Windows, 4GB or less), and 64-bit processors are capable of utilizing much more.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
