Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Restart problem BSOD, glitchy audio 1010lt Sound Card
  1. #1
    Exactly is offline New Member
    Join Date
    Sep 2012
    Posts
    8
    Default Restart problem BSOD, glitchy audio 1010lt Sound Card
    Not sure why.. usually when I shut down it restarts automatically.. recently i was watching a movie and it restarted out of no where..
    any help appreciated....
    windows ultimate 7 amd 6000 3.0 ghz processor 4 gb ram
    I did do some searching i do have m audio 1010lt and someone here had similar problems with audio being glitchy...just looking for help
    Problem signature:
    Problem Event Name: BlueScreen
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 1033
    Additional information about the problem:
    BCCode: 1000007e
    BCP1: FFFFFFFFC0000005
    BCP2: FFFFF80002D02741
    BCP3: FFFFF88003A2BB68
    BCP4: FFFFF88003A2B3C0
    OS Version: 6_1_7601
    Service Pack: 1_0
    Product: 256_1
    Files that help describe the problem:
    C:\Windows\Minidump\091412-19390-01.dmp
    C:\Users\Exactly\AppData\Local\Temp\WER-36863-0.sysdata.xml
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
    Last edited by Exactly; 14th September 2012 at 22:41. Reason: elaborating on problems
  2. #2
    Capt.Jack's Avatar
    Capt.Jack is offline Moderator
    Join Date
    Sep 2010
    Posts
    296
    Default
    Hello there!
    We need the dump file and couple of other logs to diagnosis BSOD. Follow the instructions to post the logs
    Code:
    Go to here http://majorgeeks.com/SF_Diagnostic_Tool_d6520.html and download the application.
    Right click on the application and click on Run as administrator
    Then click on Grab All
    Then go to your Desktop you'll find a folder name with today date i.e. SF_14-09-2012
    Upload the file to Sky Drive and post us the link.
  3. #3
    Join Date
    Sep 2012
    Posts
    8
    Default
    Thanks doing steps now..
  4. #4
    Join Date
    Sep 2012
    Posts
    8
    Default
    It says I can't post url's to this thread tried to pm link didn't send any options?
  5. #5
    Join Date
    Sep 2012
    Posts
    8
    Default
  6. #6
    Join Date
    Sep 2012
    Posts
    8
    Default
    take out - net to h
  7. #7
    Join Date
    Sep 2012
    Posts
    8
    Default
    any leads?
  8. #8
    Capt.Jack's Avatar
    Join Date
    Sep 2010
    Posts
    296
    Default
    Hello there!
    Seems like there may be multiple things going on. Remove / Update ASACPI.sys since it's a notorious for BSOD. Remove Avast and replace it with Microsoft Security Essentials. Make sure you use the removal tool to remove Avast. http://www.avast.com/uninstall-utility
    LIST OF DRIVERS
    Code:
    ASACPI.sys                  Mon Mar 28 08:00:36 2005 (42476C4C)
    Asus ATK0110 ACPI Utility (a known BSOD maker in Win7).  Also a part of the Asus PCProbe and AISuite Utilities
    http://www.carrona.org/drivers/driver.php?id=ASACPI.sys
    VTGKModeDX64.sys            Fri May 23 15:42:56 2008 (483698A8)
    BSOD BUGCHECK SUMMARY
    Code:
    Debug session time: Fri Sep 14 12:30:04.113 2012 (UTC + 5:30)
    Loading Dump File [C:\Crash Dump\091412-19390-01.dmp]
    Built by: 7601.21987.amd64fre.win7sp1_ldr.120503-2030
    System Uptime: 0 days 3:52:23.985
    BugCheck 1000007E, {ffffffffc0000005, fffff80002d02741, fffff88003a2bb68, fffff88003a2b3c0}
    Probably caused by : cdd.dll ( cdd!memmove+bd )
    Bugcheck code 1000007E
    Arguments ffffffff`c0000005 fffff800`02d02741 fffff880`03a2bb68 fffff880`03a2b3c0
    DEFAULT_BUCKET_ID:  WIN7_DRIVER_FAULT
    PROCESS_NAME:  csrss.exe
    BUGCHECK_STR:  0x7E
    FAILURE_BUCKET_ID:  X64_0x7E_cdd!memmove+bd
    BiosVersion = 0601
    BiosReleaseDate = 12/24/2008
    SystemManufacturer = System manufacturer
    SystemProductName = System Product Name
    Debug session time: Thu Sep 13 12:28:55.710 2012 (UTC + 5:30)
    Loading Dump File [C:\Crash Dump\091312-18049-01.dmp]
    System Uptime: 0 days 1:54:49.583
    BugCheck 50, {ffffffffffffffff, 0, fffff80002cb6911, 0}
    Probably caused by : memory_corruption
    Bugcheck code 00000050
    Arguments ffffffff`ffffffff 00000000`00000000 fffff800`02cb6911 00000000`00000000
    DEFAULT_BUCKET_ID:  CODE_CORRUPTION
    BUGCHECK_STR:  0x50
    PROCESS_NAME:  svchost.exe
    FAILURE_BUCKET_ID:  X64_MEMORY_CORRUPTION_LARGE_4096
    BiosVersion = 0601
    Debug session time: Thu Sep 13 00:27:33.930 2012 (UTC + 5:30)
    Loading Dump File [C:\Crash Dump\091312-22604-01.dmp]
    System Uptime: 0 days 0:53:01.803
    BugCheck 1E, {ffffffffc0000005, fffff88001274f4d, 0, ffffffffffffffff}
    *** WARNING: Unable to verify timestamp for win32k.sys
    *** ERROR: Module load completed but symbols could not be loaded for win32k.sys
    Bugcheck code 0000001E
    Arguments ffffffff`c0000005 fffff880`01274f4d 00000000`00000000 ffffffff`ffffffff
    BUGCHECK_STR:  0x1E_c0000005_R
    PROCESS_NAME:  System
    BiosVersion = 0601
    Debug session time: Wed Sep 12 13:26:10.268 2012 (UTC + 5:30)
    Loading Dump File [C:\Crash Dump\091212-27019-01.dmp]
    System Uptime: 0 days 3:17:17.071
    BugCheck 1E, {0, 0, 0, 0}
    Probably caused by : volsnap.sys ( volsnap!VspPerformanceCounters+50 )
    Arguments 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000
    BUGCHECK_STR:  0x1E
    FAILURE_BUCKET_ID:  X64_0x1E_volsnap!VspPerformanceCounters+50
    BiosVersion = 0601
    Debug session time: Sat Sep  8 11:04:01.064 2012 (UTC + 5:30)
    Loading Dump File [C:\Crash Dump\090812-22651-01.dmp]
    System Uptime: 1 days 6:18:51.812
    Probably caused by : CLASSPNP.SYS ( CLASSPNP!ClasspDequeueIdleRequest+1e )
    BUGCHECK_STR:  0x1E
    FAILURE_BUCKET_ID:  X64_0x1E_CLASSPNP!ClasspDequeueIdleRequest+1e
    BiosVersion = 0601
    End of analysis
  9. #9
    Join Date
    Sep 2012
    Posts
    8
    Default
    how do i Remove / Update ASACPI.sys?...well i found the update on asus site i am running win7 ultimate and the latest OS is has is Vista would it be safe to use this?
  10. #10
    Capt.Jack's Avatar
    Join Date
    Sep 2010
    Posts
    296
    Default
    Yes you can use that one.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
