DOWNLOAD: Best tool to repair Windows problems & optimize system performance | Best driver update software for your PC
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Audio Driver issue.. No Audio Output device installed
  1. #11
    James's Avatar
    James is offline Microsoft MVP
    Join Date
    Aug 2008
    Location
    New Brunswick, Canada
    Posts
    742
    Default
    If it's one thing I've learned in dealing with PCs over the years, it's that anything is possible with computers. Could be a loose/faulty connection? I was guessing a hardware problem since a reinstall of Windows did not help.
  2. #12
    Funnyguy is offline New Member
    Join Date
    Mar 2009
    Posts
    8
    Default
    Where would be the connection for the audio ports?..
  3. #13
    James's Avatar
    Join Date
    Aug 2008
    Location
    Posts
    742
    Default
    I have no idea. Check Acer's site for manuals, or take it to a technician for a diagnosis. You've tried everything you can do on your end: reinstall drivers, reinstall the OS. Time for a hands-on look by a specialist, I suspect.
  4. #14
    whs's Avatar
    whs
    whs is offline Gold Member
    Join Date
    Oct 2008
    Posts
    1,420
    Default
    From what you say it certainly sounds like some wire came loose. The upgrade of the RAM should not have anything to do with it. That is in a very confined area. Too bad it is already over a year old. Then you probably have no warranty left - unless you bought an extended warranty. But a loose wire you can probably not fix yourself.
  5. #15
    Join Date
    Mar 2009
    Posts
    8
    Default
    So my best bet would be to send it into Geek Squad? Or some computer store around here?
  6. #16
    nitinagarwal1988's Avatar
    nitinagarwal1988 is offline Microsoft MVP
    Join Date
    Jan 2009
    Location
    Pilani, India
    Posts
    1,570
    Default
    yeah, did you download and install the latest driver from the vendor's site after the fresh installation of OS? but vista have generic sound drivers and provides sound by default in most of the systems, this may also happend due to the hardware conflict as stated by james n whs. let it handle to some hardware expert...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
